WIFI 5G ESSID Disappeared
2023/01/31 11:19
Ver.1.07
・製品名・型番(例:WMC-2HC-Wなど)
WRC-XE5400GS-G
The router manually sets the 5G channel at 36, and the channel automatically switches to 108 the next day. Many devices cannot retrieve the 5G essid
When the router is "離れ家モード®", you can only use W56 band (100ch - 144ch). Please refer below. (Sorry, I cannot find the English page)
https://www.elecom.co.jp/support/manual/network/wireless-lan/router/wrc-xe5400gs/usersmanual/04/section06.html
