HHKB BT keep disconnect
2024/11/26 23:37
Hi, I'm Korean and I am living in Korea.
I'm using HHKB Hybrid Type-S and I'm really satisfied to using it everyday.
But I have an HHKB BT black, but it keeps disconnect from my mac book pro time to time and it is too annoying to use with it.
I would like to give it to my team's junior colleague but I think I have to fix it first before to give it to other.
I've heard firmware upgrading would fix this issue, but I believe this BT model can not be upgraded at home.
How can I fix my BT? Thanks.
回答 (1件中 1~1件目)
2024/11/27 00:13
Please note that this answer is based on Google Translate.
After looking into the relevant information, I found that the HHKB BT in question was indeed in communication with the manufacturer and that the firmware update was sent by the manufacturer.
I found two Japanese websites that were compiled by people who had been in communication with the manufacturer.
You should be able to confirm the content by using the English translation.
I have also attached the URL of the website.
https://www.infrastudy.com/?p=736#toc1
https://shimimin.hatenablog.com/entry/2019/12/14/001905
