Do I Need an Antivirus Software for my Lenovo ThinkPad?
2023/10/13 10:25
- Find out if the pre-installed Microsoft Defenderウイルス対策 application on your Lenovo ThinkPad is enough to protect against viruses or if you should consider buying an antivirus software for better protection.
- Learn more about the antivirus protection provided by the pre-installed Microsoft Defenderウイルス対策 application on your Lenovo ThinkPad and whether it is sufficient to keep your computer safe from viruses.
- Discover if the built-in virus protection of the Microsoft Defenderウイルス対策 application on your Lenovo ThinkPad is adequate or if investing in a dedicated antivirus software is recommended.
シリアル番号:P*******
2021/06/22 10:50
I just bought a lenovo thinkpad with serial number as in the title. It has a pre-installed Microsoft Defenderウイルス対策 application with it. Does this application is enough to be protected against viruses or should I buy an antivirus for better protection against viruses? Just getting to know my computer. I will appreciate any comments, thank you.
Hi,
Some people install antivirus software that is different from those who think Windows Defender is sufficient.
This is at the discretion of the user, but there is also a method of selecting a virus definition file that is updated frequently or that the software operates lightly.
If you are infected with a virus using Windows Defender, you should choose another software.
Windows Defender does not update frequently, so you may want to use other antivirus software.
There are Avast, AVG, Avira, Kaspersky, etc. and paid and free versions, so give it a try.
Best regards.
For general use, Virus Soft Windows Defender installed on Windows 10 is sufficient. Other functions
If you want to use Virus Soft, you have to be able to use it yourself.
タイトルにあるシリアルナンバーのレノボ・シンクパッドを購入しました。
マイクロソフト社製ディフェンダーウイルス対策アプリケーションがプレインストール
されています。 このアプリケーションだけでウイルス対策は十分なの
でしょうか、それともウイルス対策のためにウィルス対策ソフトを購
入したほうがいいのでしょうか?私は自分のコンピュータを知りたい
だけなのです。 何かコメントがありましたら、よろしくお願いします。
ウィルスソフトはお好みで。
無料版を使うも良し。
https://www.kingsoft.jp/is/kislp/1910y.html?utm_source=yahoo&utm_medium=cpc&utm_campaign=KIS20&utm_term=lp1910&yclid=YSS.1000062222.EAIaIQobChMIlKK4yO208AIVJ8BMAh2ClAS-EAAYASAAEgJNYfD_BwE
https://www.kingsoft.jp/is/shop?ref=footer
