mouse assistant 5 not able to assign functions to certain buttons. also, when i assign a function to the corresponding numbered button, the function operates on another button. e.g., volume up assigned tp button 7, but works on button 9 instead...is the assistant not compatible with windows 11? or, is there something i nbeed to do with a setting on my pc prior to using the assistant?
In this trouble, Mouse Assistant is not the cause.
The cause may be that M-RT1BR does not support Windows 11.
Windows 11 is not in the result on the manufacturer's correspondence table.
https://www.elecom.co.jp/global/download/manual/pdf/20200422_MSC-M-RT1BR_ALL_ver.1.pdf
This product is compatible with Windows 10.
Unfortunately it is not available for windows 11.
https://www.elecom.co.jp/products/M-RT1BRBK.html
