ELECOM Hello Err3
2023/10/06 02:07
===scale===
・製品型番(例:HCS-WFS01など)
===HCS-FS01===
===when i get on the scale to measure my body mass===
▼お困りごとの詳細、自分が使っている機器の状況や、表示される内容をお書きください。(例:アプリとペアリングできない・設定ができない・使い方がわからない)
==When i get on the scale to measure my body fat measurement, it appears the error 3, and everything ive done is correct===
The manual page 27 saids:
+ Did you get on it before automatic correction finished?
+ Didn't you move while measuring?
+ Your foot sole clean?
+ Didn't you wear socks?
If these are clear, consult the support center.
