UCAM-CF20FBBK
2023/12/10 14:01
・ご利用の製品タイプ(例:アダプター)
PC Webcam
・製品名・型番(例:U2C-AC05BK)
UCAM-CF20FBBK
Windows 11 64-bit
Whenever I startup my PC into the user login page
The UCAM-CF20FBBK Webcam takes too long to turn on for Windows Hello (>10 seconds) whenever I startup/restart my PC.
Is there anyone here facing the same issue, and how should i go about fixing it.
The driver seems to support only by Windows 10.
https://www.elecom.co.jp/support/download/peripheral/pccamera/ucam-cf20fb/
Will you try to use the following ?
https://www.elecom.co.jp/support/download/peripheral/pccamera/assistant/soft/index.html
