TK-FBM120KBK Models
2024/04/09 00:28
Keyboard
TK-FBM120KBK vs. TK-FBM120KBK/EC
・発生時期(※使えていた時期がありますか?)
Not yet, I had just ordered the TK-FBM120KBK/EC from Amazon JP.
First of all, I am sorry that I am not typing this in Japanese, however I still do not know enough Japanese for that (I ordered this keyboard to help me learn Japanese).
I noticed that on the Elecom website there are 2 TK-FBM120KBK models, the TK-FBM120KBK and the TK-FBM120KBK/EC, with TK-FBM120KBK being more expensive, and I was wondering how they are different, as I could not find anything.
Also, is there a USB (not Bluetooth) receiver for the TK-FBM120KBK/EC? Since while I will be mainly using it with Bluetooth, I would like to be able to use the same keyboard without adding a Bluetooth adapter to some computers, like I can with my Lenovo Howard mouse, Lenovo ThinkLife WLM210 mouse, Asus Adol MS012 mouse and Logitech mice and keyboards.
The TK-FBM120KBK/EC model number is a model limited to sales channels such as Amazon.
It is a low-priced product with a specified vendor, and the performance of the device is considered to be the same as TK-FBM120KBK.
Not limited to the TK-FBM120KBK/EC, Bluetooth compatible keyboards can be paired with multiple devices and used simultaneously if the computer has a Bluetooth pairing function.
Thank you very much for the explanation, that certainly makes sense.
And I understand that there is no optional 2.4Ghz RF receiver, only Bluetooth, yes?
If so, it is a slight disappointment, but not much.
あなたの知識・経験で困っている人を助けてみませんか?
「助け合い」の輪を広げるOKWAVEで回答をお願いします!
2024/04/11 15:38
Would that be a Bluetooth receiver, or a standard 2.4Ghz RF receiver?
